EcoFlow RIVER 2 Max draagbare energiecentrale
EcoFlow-Netherland
Nu kopen, later betalen
30 dagen garantie
Snelle en gratis verzending
Garantiebescherming
Levenslange ondersteuning
Zomeruitverkoop🏖️
Normale prijs €354,90 EUR
Verkoopprijs €354,90 EUR Normale prijs €469,00
Verkoop Uitverkocht
Bespaar tot €230
Eenheidsprijs
Inclusief belasting.
•512Wh capaciteit en 500W output.
•Lever tot 1,5 kWh per dag met opladen via zonne-energie.
•Snelste oplaadtijd 0-100% in slechts 60 min.
•Veiligste LFP-batterij gaat 10 jaar mee.
•Eerste elektriciteitscentrale met een TÜV Rheinland-veiligheidscertificaat.
•Lichtgewicht van slechts 6,1 kg.
•Verhoog het vermogen tot 1000 W en laat 80% van de essentiële apparaten werken.
•4 manieren om op te laden: AC, auto, zonne-energie en USB-C.
•Slimme app-bediening met Bluetooth of Wi-Fi.
Overzicht
Optie
Gratis River Series Bag bij RIVER 2 Max
€354,90 EUR €469 -€114,10
Power. Never Been This Easy
Charge 0-100% in 1 Hour
Fastest charging speeds ever.
RIVER 2 Max beats the industry charging speed standard, fully charging in only 60 minutes. That’s 5x faster than other portable power stations on the market and 38% quicker than previous generations. Fully charge RIVER 2 Max while you pack your bags, so you’ll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times. That’s pretty much 10 years of everyday use [1] and 6x longer than the industry average. With LFP cells, RIVER 2 Series is safe, durable, and highly efficient, even in warm temperatures.
5-year Warranty
4 Ways to Charge
Charge anywhere.
With 4 different ways to top up the RIVER 2 Series, there’s a recharge option no matter what.3From fast AC to in-car charging when you’re on the go.
AC Charging
Car Charging
USB-C Charging
Why not harness renewable energy while you camp or head off on a trip? Plug in a couple of portable solar panels to fully recharge off-grid in as fast as 3 hours.
X-Boost Up to 1000W
Small size. Big power.
RIVER 2 Max has an AC output of up to 500W. Need to power a vacuum cleaner or sandwich maker? Crank it up to 1000W with X-Boost mode to run up to 80% of high-wattage appliances.
Lightweight at only 6 kg
With a compact portable design, taking travel-friendly power off-grid has never been this easy. With a light-weight that’s 22% lighter than the previous generation, RIVER 2 Max is ready to power all your outdoorsy escapades, from boondocking to BBQs at the beach.
Monitor Monitor
Monitor
Real-time energy insights on the go.
View battery status live anytime, anywhere.
Control Control
Control
Control even from afar.
Easily turn on/off output and the connected appliances remotely.
Customize Customize
Customize
Elevated battery lifespan and safety.
By tuning the charging speed to suit various charging environments, it's safe to use, preventing overloading and prolonging its lifespan.
Customize Customize
Customize
Stay calm and powered on.
When the power's down, AC Always-On ensures a seamless transition from the grid to backup power and unwavering protection of your fridge and other mission-critical appliances.
Constant Updates
Constant updates for optimal user experience.
Regular upgrades to offer you industry-leading energy management.
Power. Anywhere. Anytime.
1. RIVER 2 Max 2. AC Charging Cable 3. Quick Start Guide
512Wh
Approximately 6kg
270 x 260 x 196mm
AC Input
220-240V~ 50Hz/60Hz, 660W Max
Solar Input
11-50V 13A, 220W Max
Car Input
12V/24V, 8A, 100W Max
USB-C Input/Output
5/9/12/15/20V, 5A, 100W Max
DC Output
12.6V, 10A/3A/3A, 126W Max
Cell Chemistry
Discharge Temperature
-10°C to 45°C
Charge Temperature
0°C to 45°C
Optimal Operating Temperature
20°C to 30°C
Storage Temperature
-10°C to 45°C (20°C to 30°C is best)
DC5521 Output
12.6V, 3A, 36W Max
App Control
Wi-Fi, Bluetooth
1. Using RIVER 2 Max six times a week, 3000 full 100% cycles will last 9.6 years until it drops to 80%.
3. When charging and discharging at high wattage, RIVER 2 Max may make a noise up to 62db.
Upload bewijs van verblijf
4. Upload de afbeelding
